Ansys Learning Forum Forums Discuss Simulation Photonics How to calculate the resistance of a PIN modulator in charge Reply To: How to calculate the resistance of a PIN modulator in charge
kghaffari
You can perform a small signal analysis (for a range of frequencies) and then derive internal resistance from the real part of impedance.
This approach is used in the travelling wave modulator example (here is the link). This approach is used in Step 2/5 of the workflow; the post-processing can be found in the script "tw_modulator_DEVICE_ac_RC.lsf".
Best regards
