Ansys Learning Forum Forums Discuss Simulation Fluids Deformed geometry by adjoint solver Reply To: Deformed geometry by adjoint solver
Murari Iyengar
I also recommend checking the observable you've defined along with the target, morphing method, design conditions, region. You can find information regarding the same in the link attached above.
If you want to mesh the .stl file, you can open it in any CAD software and continue as you normally would.Â
