Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid › Reply To: TIED_CONTACT for Shell Elements – Gap between Shell-Shell and Shell-Solid
Luisa Hornung
I read somewhere that when using constraint-based contact one node can not be tied twice to different other parts. I think that is the problem. However, I consider the problem solved. Thank you for your support.
