Ansys Learning Forum Forums Discuss Simulation Preprocessing Error when replacing the geometry Reply To: Error when replacing the geometry
Matthias Duve
Hi, have a similar issue.
I want to replace only one geometry (part) in an assembly in mechanical. I only seem to be able to replace the whole assembly with the standard prompts. If I do so, all external points, connections, joints eg only have question marks on them afterwards and won´t work. Event on the parts that are exactly the same than before.
Any ideas how to solve this?
Thanks a lot!
