Ansys Learning Forum Forums Discuss Simulation General Mechanical Save thermal results in txt file via /post1 snippet Reply To: Save thermal results in txt file via /post1 snippet
John Miller
Hello Chandra,
thank you for the helpfull answer.
When I apply the mentioned lines to my code:
nodeid=27844
/post26
nsol,2,node,nodeid,temp !Specifies nodal data to be stored from the results file
prvar,2                              !Lists variables vs. time (or frequency).
plvar,2                              !Displays up to ten variables in the form of a graph.
/out,d:\mypvar.dat
prvar,2
/out
/show,png
plvar,2
/show,close
this is the outcome in the solve.out file:
          ***** TIME-HISTORY POSTPROCESSOR (POST26) *****
 ALL POST26 SPECIFICATIONS ARE RESET TO INITIAL DEFAULTS
 *** WARNING ***                         CP =     418.125   TIME= 13:48:41
 The data in field 3 is invalid.  The NSOL command is ignored.
 No data points are saved during this storage step.
 /OUTPUT FILE= d:\mypvar.dat
 /SHOW SWITCH PLOTS TO  PNG         - RASTER MODE.
 Set Encoding of XML File to:ISO-8859-1
 Set Output of XML File to:
     PARM,     ,     ,     ,     ,     ,     ,     ,     ,     ,     ,     ,
 DATABASE WRITTEN ON FILE  parm.xml
 ***** ROUTINE COMPLETED *****  CP =       419.062
 PRINTOUT RESUMED BY /GOP
 *GET  _WALLDONE  FROM  ACTI  ITEM=TIME WALL  VALUE=  13.8116667
 PARAMETER _PREPTIME =     1.000000000
 PARAMETER _SOLVTIME =     150.0000000
 PARAMETER _POSTTIME =     4.000000000
 PARAMETER _TOTALTIM =     155.0000000
 *GET  _DLBRATIO  FROM  ACTI  ITEM=SOLU DLBR  VALUE=  0.00000000
 *GET  _COMBTIME  FROM  ACTI  ITEM=SOLU COMB  VALUE=  0.00000000
 *GET  _SSMODE   FROM  ACTI  ITEM=SOLU SSMM  VALUE=  2.00000000
 *GET  _NDOFS    FROM  ACTI  ITEM=SOLU NDOF  VALUE=  122196.000
 --- Total number of nodes = 283054
 --- Total number of elements = 84182
 --- Element load balance ratio = 0
 --- Time to combine distributed files = 0
 --- Sparse memory mode = 2
 --- Number of DOF = 122196
 EXIT ANSYS WITHOUT SAVING DATABASE
 NUMBER OF WARNING MESSAGES ENCOUNTERED=         30
 NUMBER OF ERROR   MESSAGES ENCOUNTERED=          0
Obviously, the nodal data isn't stored at all.
With best regards
John M.
