Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Inserting a command in WB to define nonlinear orthotropic material › Reply To: Inserting a command in WB to define nonlinear orthotropic material
wancheng gao
Hello MJ, that is awesome that your reply confirms what I have set up is correct except that the element orientation part is unnecessary!
One more question, if I want to obtain the three stresses components in elemental CS, I have to switch to "Solution coordinate system", am I right?
Thank you!!!
