Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Difference between Dead and Solid regions Fluent Meshing › Reply To: Difference between Dead and Solid regions Fluent Meshing
In Fluent you can append mesh files, so it may be easiest to put a mesh onto the casing and read it into the solved model.
