Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Bent waveguide design › Reply To: Bent waveguide design
Then Elango
Thank you very much for the reply.
L is 90, and U is 180 (they are called that because of the shape of the letters is similar to the angles. )
Yes, I have both FDE and FDTD, I want to see the loss and I would like to know how to calculate the dimensions of waveguide  for particulator wavelength of the light source and I my material is a polymer of particular fixed refractive index. I mean, what width and height to use for 1550 nm and what should be the bend radius,
