Ansys Learning Forum Forums Discuss Simulation Fluids An error has occurred in cfx5solve:The ANSYS CFX solver exited with return code1 Reply To: An error has occurred in cfx5solve:The ANSYS CFX solver exited with return code1
Stefano Chieti
Hello Chaitanya,
thank you for your prompt reply! I can easely agree with any of your setup statements, I know that can be far from good or "correct".
The real fact is that I had a project in FluidFlow (CFX), with the same exact setup, which was solved withou errors and gave me results. My very first attempt was to change some setup input values. Then I found errors. My second attempt was then to simply re-run the same exact setup in that project, which eventually led to errors where previously where not!
My last attempt has been to reproduce from scratch in another project, with the same first solved setup, but still getting errors.
The fact which triggers me is that the initial, solved, project is not able to be solved anymore without changing anything, exept for the directory location on my workstation (the workstation and release of ANSYS is the same). This is why I also thought about some licensing or directory path problem.
I attach the initial project .outfile if can be usefull. I double-checked it and it's exaclty the same as the one atteched in the starting thread.
 This run of the CFX 2021 R1 Solver started at 10:08:45 on 08 Feb 2022
 by user Stefano.CHIETI on ------- (intel_xeon64.sse2_winnt) using the
 command:
  "C:\Program Files\ANSYS Inc\v211\CFX\bin\perllib\cfx5solve.pl" -batch
    -ccl runInput.ccl -fullname CFX_003
 2021 R1
  Point Releases and Patches installed:
  ANSYS, Inc. Products 2021 R1
  SpaceClaim 2021 R1
  Autodyn 2021 R1
  CFD-Post only 2021 R1
  CFX (includes CFD-Post) 2021 R1
  FENSAP-ICE 2021 R1
  Fluent (includes CFD-Post) 2021 R1
  Forte (includes EnSight) 2021 R1
  Polyflow (includes CFD-Post) 2021 R1
  TurboGrid 2021 R1
  Aqwa 2021 R1
  Customization Files for User Programmable Features 2021 R1
  Mechanical Products 2021 R1
  Icepak (includes CFD-Post) 2021 R1
  Remote Solve Manager Standalone Services 2021 R1
  Viewer 2021 R1
  ACIS Geometry Interface 2021 R1
  AutoCAD Geometry Interface 2021 R1
  Catia, Version 4 Geometry Interface 2021 R1
  Catia, Version 5 Geometry Interface 2021 R1
  Catia, Version 6 Geometry Interface 2021 R1
  Creo Elements/Direct Modeling Geometry Interface 2021 R1
  Creo Parametric Geometry Interface 2021 R1
  Inventor Geometry Interface 2021 R1
  JTOpen Geometry Interface 2021 R1
  NX Geometry Interface 2021 R1
  Parasolid Geometry Interface  2021 R1
  Solid Edge Geometry Interface 2021 R1
  SOLIDWORKS Geometry Interface 2021 R1
  ANSYS, Inc. License Manager 2021 R1
 Setting up CFX Solver run ...
 |                    CFX Command Language for Run                    |
 LIBRARY:
   MATERIAL: Water
     Material Description = Water (liquid)
     Material Group = Water Data, Constant Property Liquids
     Option = Pure Substance
     Thermodynamic State = Liquid
     PROPERTIES:
       Option = General Material
       EQUATION OF STATE:
         Density = 997.0 [kg m^-3]
         Molar Mass = 18.02 [kg kmol^-1]
         Option = Value
       END
       SPECIFIC HEAT CAPACITY:
         Option = Value
         Specific Heat Capacity = 4181.7 [J kg^-1 K^-1]
         Specific Heat Type = Constant Pressure
       END
       REFERENCE STATE:
         Option = Specified Point
         Reference Pressure = 1 [atm]
         Reference Specific Enthalpy = 0.0 [J/kg]
         Reference Specific Entropy = 0.0 [J/kg/K]
         Reference Temperature = 25 [C]
       END
       DYNAMIC VISCOSITY:
         Dynamic Viscosity = 8.899E-4 [kg m^-1 s^-1]
         Option = Value
       END
       THERMAL CONDUCTIVITY:
         Option = Value
         Thermal Conductivity = 0.6069 [W m^-1 K^-1]
       END
       ABSORPTION COEFFICIENT:
         Absorption Coefficient = 1.0 [m^-1]
         Option = Value
       END
       SCATTERING COEFFICIENT:
         Option = Value
         Scattering Coefficient = 0.0 [m^-1]
       END
       REFRACTIVE INDEX:
         Option = Value
         Refractive Index = 1.0 [m m^-1]
       END
       THERMAL EXPANSIVITY:
         Option = Value
         Thermal Expansivity = 2.57E-04 [K^-1]
       END
     END
   END
 END
 FLOW: Flow Analysis 1
   SOLUTION UNITS:
     Angle Units = [rad]
     Length Units = [m]
     Mass Units = [kg]
     Solid Angle Units = [sr]
     Temperature Units = [K]
     Time Units = [s]
   END
   ANALYSIS TYPE:
     Option = Steady State
     EXTERNAL SOLVER COUPLING:
       Option = None
     END
   END
   DOMAIN: CONVERGENT
     Coord Frame = Coord 0
     Domain Type = Fluid
     Location = B2646
     BOUNDARY: CONVERGENT Default
       Boundary Type = WALL
       Location = F2647.2646
       BOUNDARY CONDITIONS:
         MASS AND MOMENTUM:
           Option = No Slip Wall
         END
         WALL ROUGHNESS:
           Option = Smooth Wall
         END
       END
     END
     BOUNDARY: Interface Convergent Volute Side 1
       Boundary Type = INTERFACE
       Location = F1861.2646
         MASS AND MOMENTUM:
           Option = Conservative Interface Flux
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: OUTLET
       Boundary Type = OUTLET
       Location = F2648.2646
         FLOW REGIME:
           Option = Subsonic
         END
         MASS AND MOMENTUM:
           Mass Flow Rate = 0.63 [kg s^-1]
           Mass Flow Rate Area = As Specified
           Option = Mass Flow Rate
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
         Option = Non Buoyant
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
     FLUID DEFINITION: Fluid 1
       Material = Water
       Option = Material Library
       MORPHOLOGY:
         Option = Continuous Fluid
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
       HEAT TRANSFER MODEL:
         Option = None
       END
       THERMAL RADIATION MODEL:
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
       TURBULENT WALL FUNCTIONS:
         Option = Automatic
       END
     END
   END
   DOMAIN: DUCTS
     Domain Type = Fluid
     Location = B188,B189,B26,B27
     BOUNDARY: DUCTS Default
       Location = \
         F21.188,F22.27,F23.189,F24.26,F254.188,F255.188,F256.188,F258.188,F25\
         9.189,F260.189,F261.189,F263.189,F271.189,F272.189,F273.189,F274.189,\
         F275.189,F276.189,F277.189,F278.189,F279.188,F280.188,F281.188,F282.1\
         88,F2828.26,F2829.26,F283.188,F2832.27,F2833.27,F2836.188,F2837.188,F\
         284.188,F2840.189,F2841.189,F285.188,F286.188,F287.26,F288.26,F289.26\
         ,F290.26,F291.26,F292.26,F293.26,F294.26,F295.27,F296.27,F297.27,F298\
         .27,F299.27,F300.27,F301.27,F302.27,F303.27,F304.27,F306.27,F307.27,F\
         310.26,F311.26,F312.26,F314.26
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: Interface Ducts RotatingCoolingDX Xdir Side 1
       Location = \
         F2657.26,F2658.189,F2659.27,F2660.188,F2666.188,F2667.27,F2668.189,F2\
         669.26
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface Ducts RotatingCoolingDX Zdir Side 1
       Location = F2662.26,F2663.189,F2664.27,F2665.188
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: EULERIAN
     Domain Type = Fluid
     Location = B2640
     BOUNDARY: EULERIAN Default
       Location = F2641.2640
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: INLET
       Boundary Type = INLET
       Location = F2642.2640
         FLOW DIRECTION:
           Option = Normal to Boundary Condition
         END
         FLOW REGIME:
           Option = Subsonic
         END
         MASS AND MOMENTUM:
           Option = Total Pressure
           Relative Pressure = 185 [kPa]
         END
         TURBULENCE:
           Option = Medium Intensity and Eddy Viscosity Ratio
         END
       END
     END
     BOUNDARY: Interface Eulerian Intake Side 1
       Location = F2759.2640
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: INTAKE
     Domain Type = Fluid
     Location = B67
     BOUNDARY: INTAKE Default
       Location = F2868.67,F436.67
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: Interface Eulerian Intake Side 2
       Location = F2759.67
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface Intake IntakeMaze Side 1
       Location = F2875.67
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: INTAKE MAZE
     Domain Type = Fluid
     Location = B2761
     BOUNDARY: INTAKE MAZE Default
       Location = \
         F427.2761,F428.2761,F429.2761,F430.2761,F431.2761,F432.2761,F433.2761\
         ,F434.2761,F899.2761,F904.2761,F906.2761,F907.2761,F909.2761,F910.276\
         1,F911.2761,F912.2761,F913.2761
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: Interface Intake IntakeMaze Side 2
       Location = F2875.2761
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface IntakeMaze RotatingImpeller Side 1
       Location = F211.2761,F2874.2761
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: ROTATING BOLT
     Domain Type = Fluid
     Location = B2687
     BOUNDARY: Interface RotatingBolt RotatingImpeller Side 1
       Location = F2699.2687,F2700.2687,F2701.2687,F2702.2687
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingBolt RotatingShaft Side 1
       Location = F2672.2687
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: ROTATING BOLT Default
       Frame Type = Rotating
       Location = \
         F1096.2687,F1097.2687,F236.2687,F237.2687,F238.2687,F239.2687,F2670.2\
         687,F2675.2687,F2703.2687,F872.2687,F873.2687,F888.2687,F915.2687,F93\
         8.2687,F939.2687,F940.2687
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Alternate Rotation Model = true
         Angular Velocity = -1256.64 [radian s^-1]
         Option = Rotating
         AXIS DEFINITION:
           Option = Coordinate Axis
           Rotation Axis = Coord 0.3
         END
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: ROTATING COOLING CENTER
     Domain Type = Fluid
     Location = B2762
     BOUNDARY: Interface RotatingCoolingCENTER RotatingCoolingDX Side 1
       Location = F2778.2762
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingCoolingSX RotatingCoolingCENTER Side 2
       Location = F2804.2762
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: ROTATING COOLING CENTER Default
       Location = F2781.2762
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: StaticWalls CoolingCENTER
       Location = F2779.2762
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Rotating
         AXIS DEFINITION:
         END
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: ROTATING COOLING DX
     Domain Type = Fluid
     Location = B2787
     BOUNDARY: Interface Ducts RotatingCoolingDX Xdir Side 2
       Location = \
         F2657.2787,F2658.2787,F2659.2787,F2660.2787,F2666.2787,F2667.2787,F26\
         68.2787,F2669.2787
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface Ducts RotatingCoolingDX Zdir Side 2
       Location = F2662.2787,F2663.2787,F2664.2787,F2665.2787
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingCoolingCENTER RotatingCoolingDX Side 2
       Location = F2778.2787
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingCoolingDX RotatingShaft Side 1
       Location = F2688.2787
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: ROTATING COOLING DX Default
       Location = \
         F10.2787,F1000.2787,F1001.2787,F1002.2787,F1003.2787,F1004.2787,F1005\
         .2787,F1006.2787,F1007.2787,F1008.2787,F1009.2787,F1010.2787,F1011.27\
         87,F1012.2787,F1013.2787,F1014.2787,F1015.2787,F1016.2787,F1017.2787,\
         F1018.2787,F1019.2787,F1020.2787,F1021.2787,F1022.2787,F1023.2787,F10\
         24.2787,F1025.2787,F1026.2787,F1027.2787,F1028.2787,F1029.2787,F1030.\
         2787,F1031.2787,F1032.2787,F1033.2787,F1034.2787,F1035.2787,F1036.278\
         7,F1037.2787,F1038.2787,F1039.2787,F1040.2787,F1041.2787,F1042.2787,F\
         1043.2787,F1044.2787,F1045.2787,F1046.2787,F1047.2787,F1048.2787,F104\
         9.2787,F1050.2787,F1051.2787,F1052.2787,F1053.2787,F1054.2787,F1055.2\
         787,F1056.2787,F1057.2787,F1058.2787,F1059.2787,F1060.2787,F1061.2787\
         ,F1062.2787,F1063.2787,F1064.2787,F1065.2787,F1066.2787,F1067.2787,F1\
         068.2787,F1069.2787,F1070.2787,F1071.2787,F1072.2787,F1073.2787,F1074\
         .2787,F1075.2787,F1076.2787,F1077.2787,F1078.2787,F1079.2787,F1080.27\
         87,F1081.2787,F1082.2787,F1083.2787,F1084.2787,F1085.2787,F1086.2787,\
         F1087.2787,F1088.2787,F1089.2787,F1090.2787,F11.2787,F1111.2787,F1112\
         .2787,F1113.2787,F1114.2787,F1115.2787,F1116.2787,F1117.2787,F2713.27\
         87,F2782.2787,F32.2787,F36.2787,F37.2787,F38.2787,F39.2787,F4.2787,F4\
         0.2787,F41.2787,F42.2787,F43.2787,F44.2787,F45.2787,F46.2787,F47.2787\
         ,F48.2787,F49.2787,F5.2787,F50.2787,F6.2787,F7.2787,F8.2787,F867.2787\
         ,F868.2787,F869.2787,F9.2787,F918.2787,F929.2787,F930.2787,F931.2787,\
         F932.2787,F933.2787,F934.2787,F935.2787,F936.2787,F941.2787,F942.2787\
         ,F943.2787,F944.2787,F948.2787,F951.2787,F952.2787,F953.2787,F954.278\
         7,F955.2787,F956.2787,F957.2787,F958.2787,F959.2787,F960.2787,F961.27\
         87,F962.2787,F974.2787,F975.2787,F976.2787,F977.2787,F978.2787,F979.2\
         787,F980.2787,F981.2787,F982.2787,F983.2787,F984.2787,F985.2787,F986.\
         2787,F987.2787,F988.2787,F989.2787,F990.2787,F991.2787,F992.2787,F993\
         .2787,F994.2787,F995.2787,F996.2787,F997.2787,F998.2787,F999.2787
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: StaticWalls CoolingDX
       Location = \
         F1841.2787,F1842.2787,F185.2787,F204.2787,F243.2787,F245.2787,F264.27\
         87,F266.2787,F265.2787,F267.2787,F268.2787,F2689.2787,F269.2787,F270.\
         2787,F308.2787,F309.2787,F315.2787,F320.2787,F321.2787,F322.2787,F323\
         .2787,F324.2787,F33.2787,F2780.2787,F35.2787
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Rotating
         AXIS DEFINITION:
         END
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: ROTATING COOLING SX
     Domain Type = Fluid
     Location = B2698
     BOUNDARY: Interface RotatingCoolingSX RotatingCoolingCENTER Side 1
       Location = F2804.2698
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingSpillage RotatingCoolingSX Side 2
       Location = F2671.2698
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface SpillageDX RotatingCoolingSX Side 2
       Location = F207.2698
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: ROTATING COOLING SX Default
       Location = \
         F1100.2698,F1101.2698,F1102.2698,F1103.2698,F1104.2698,F1105.2698,F11\
         06.2698,F1107.2698,F1108.2698,F1109.2698,F2674.2698,F2806.2698,F31.26\
         98,F916.2698,F919.2698,F920.2698,F921.2698,F922.2698,F923.2698,F924.2\
         698,F925.2698,F926.2698,F927.2698,F928.2698,F946.2698
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: StaticWalls CoolingSX
       Location = F1856.2698,F2712.2698,F2805.2698
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Rotating
         AXIS DEFINITION:
         END
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: ROTATING IMPELLER
     Domain Type = Fluid
     Location = B2686
     BOUNDARY: Interface IntakeMaze RotatingImpeller Side 2
       Location = F211.2686,F2874.2686
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingBolt RotatingImpeller Side 2
       Location = F2699.2686,F2700.2686,F2701.2686,F2702.2686
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingImpeller RotatingSpillage Side 1
       Location = F2710.2686
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingImpeller Volute Side 1
       Location = F2727.2686
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: ROTATING IMPELLER Default
       Location = \
         F100.2686,F101.2686,F102.2686,F103.2686,F104.2686,F105.2686,F106.2686\
         ,F107.2686,F1091.2686,F1092.2686,F1093.2686,F1094.2686,F1095.2686,F10\
         99.2686,F69.2686,F77.2686,F78.2686,F79.2686,F80.2686,F81.2686,F82.268\
         6,F83.2686,F84.2686,F85.2686,F86.2686,F87.2686,F875.2686,F876.2686,F8\
         77.2686,F878.2686,F879.2686,F88.2686,F880.2686,F881.2686,F882.2686,F8\
         83.2686,F884.2686,F885.2686,F887.2686,F89.2686,F891.2686,F892.2686,F8\
         93.2686,F894.2686,F895.2686,F896.2686,F897.2686,F898.2686,F90.2686,F9\
         1.2686,F92.2686,F93.2686,F94.2686,F95.2686,F96.2686,F97.2686,F98.2686\
         ,F99.2686
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: StaticWalls IMPELLER
       Location = \
         F1869.2686,F420.2686,F421.2686,F422.2686,F423.2686,F424.2686,F425.268\
         6,F426.2686,F70.2686,F900.2686,F901.2686,F902.2686,F903.2686,F905.268\
         6,F908.2686,F1860.2686,F1867.2686,F1868.2686,F193.2686,F209.2686,F210\
         .2686,F2683.2686
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Rotating
         AXIS DEFINITION:
         END
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: ROTATING SHAFT
     Domain Type = Fluid
     Location = B2681
     BOUNDARY: Interface RotatingBolt RotatingShaft Side 2
       Location = F2672.2681
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingCoolingDX RotatingShaft Side 2
       Location = F2688.2681
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: ROTATING SHAFT Default
       Location = \
         F2676.2681,F937.2681,F963.2681,F964.2681,F965.2681,F966.2681,F967.268\
         1,F968.2681,F969.2681,F970.2681,F971.2681,F972.2681,F973.2681
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Rotating
         AXIS DEFINITION:
         END
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: ROTATING SPILLAGE
     Domain Type = Fluid
     Location = B2680
     BOUNDARY: Interface RotatingImpeller RotatingSpillage Side 2
       Location = F2710.2680
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingSpillage RotatingCoolingSX Side 1
       Location = F2671.2680
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingSpillage SpillageSX Side 1
       Location = F2722.2680,F2723.2680,F2724.2680,F2725.2680,F2726.2680
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface SpillageCENTER RotatingSpillage Side 2
       Location = F1847.2680
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: ROTATING SPILLAGE Default
       Location = \
         F235.2680,F2673.2680,F2709.2680,F73.2680,F74.2680,F75.2680,F76.2680,F\
         870.2680,F871.2680,F890.2680,F914.2680,F917.2680,F949.2680,F950.2680
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     BOUNDARY: StaticWalls Spillage
       Location = \
         F1848.2680,F241.2680,F2682.2680,F331.2680,F332.2680,F333.2680,F334.26\
         80,F335.2680,F336.2680,F337.2680,F338.2680,F339.2680,F340.2680,F341.2\
         680,F342.2680,F362.2680,F395.2680,F396.2680,F397.2680,F398.2680,F399.\
         2680,F400.2680,F72.2680,F201.2680
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Rotating
         AXIS DEFINITION:
         END
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: SPILLAGE CENTER
     Domain Type = Fluid
     Location = B2862
     BOUNDARY: Interface SpillageCENTER RotatingSpillage Side 1
       Location = F1847.2862
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface SpillageCENTER SpillageDX Side 1
       Location = F2788.2862
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface SpillageCENTER SpillageSX Side 1
       Location = F2764.2862
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface SpillageVolute SpillageCENTER Side 2
       Location = F2763.2862
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: SPILLAGE CENTER Default
       Location = \
         F2768.2862,F2770.2862,F2790.2862,F2793.2862,F2864.2862,F326.2862,F343\
         .2862,F347.2862,F349.2862,F350.2862,F351.2862,F71.2862
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: SPILLAGE DX
     Domain Type = Fluid
     Location = B2802
     BOUNDARY: Interface SpillageCENTER SpillageDX Side 2
       Location = F2788.2802
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface SpillageDX RotatingCoolingSX Side 1
       Location = F207.2802
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: SPILLAGE DX Default
       Location = \
         F1855.2802,F2791.2802,F2792.2802,F328.2802,F329.2802,F330.2802
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: SPILLAGE SX
     Domain Type = Fluid
     Location = B30
     BOUNDARY: Interface RotatingSpillage SpillageSX Side 2
       Location = F2722.30,F2723.30,F2724.30,F2725.30,F2726.30
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface SpillageCENTER SpillageSX Side 2
       Location = F2764.30
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: SPILLAGE SX Default
       Location = \
         F246.30,F247.30,F248.30,F249.30,F250.30,F251.30,F252.30,F253.30,F2769\
         .30,F344.30,F352.30,F353.30,F354.30,F355.30,F356.30,F357.30,F358.30,F\
         359.30,F360.30,F361.30,F363.30,F364.30,F365.30,F366.30,F367.30,F368.3\
         0,F369.30,F370.30,F371.30,F372.30,F373.30,F374.30,F375.30,F376.30,F37\
         7.30,F378.30,F379.30,F380.30,F381.30,F382.30,F383.30,F384.30,F385.30,\
         F386.30,F387.30,F388.30,F389.30,F390.30,F391.30,F392.30,F393.30,F394.\
         30
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: SPILLAGE VOLUTE
     Domain Type = Fluid
     Location = B2775
     BOUNDARY: Interface SpillageVolute SpillageCENTER Side 1
       Location = F2763.2775
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface Volute SpillageVolute Side 2
       Location = F2811.2775
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: SPILLAGE VOLUTE Default
       Location = F2767.2775
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN: VOLUTE
     Domain Type = Fluid
     Location = B1834
     BOUNDARY: Interface Convergent Volute Side 2
       Location = F1861.1834
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface RotatingImpeller Volute Side 2
       Location = F2727.1834
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: Interface Volute SpillageVolute Side 1
       Location = F2811.1834
         MASS AND MOMENTUM:
         END
         TURBULENCE:
         END
       END
     END
     BOUNDARY: VOLUTE Default
       Location = \
         F1853.1834,F1862.1834,F1863.1834,F1864.1834,F1865.1834,F1866.1834,F40\
         1.1834,F402.1834,F403.1834,F404.1834,F405.1834,F406.1834,F407.1834,F4\
         08.1834,F409.1834,F410.1834,F411.1834,F412.1834,F413.1834,F414.1834,F\
         415.1834,F416.1834,F417.1834,F418.1834,F419.1834
         MASS AND MOMENTUM:
         END
         WALL ROUGHNESS:
         END
       END
     END
     DOMAIN MODELS:
       BUOYANCY MODEL:
       END
       DOMAIN MOTION:
         Option = Stationary
       END
       MESH DEFORMATION:
         Option = None
       END
       REFERENCE PRESSURE:
       END
     END
       Material = Water
       MORPHOLOGY:
       END
     END
     FLUID MODELS:
       COMBUSTION MODEL:
         Option = None
       END
         Option = None
       END
         Option = None
       END
       TURBULENCE MODEL:
         Option = SST
       END
         Option = Automatic
       END
     END
   END
   DOMAIN INTERFACE: Interface Convergent Volute
     Boundary List1 = Interface Convergent Volute Side 1
     Boundary List2 = Interface Convergent Volute Side 2
     Interface Type = Fluid Fluid
     INTERFACE MODELS:
       Option = General Connection
       FRAME CHANGE:
         Option = Frozen Rotor
       END
       MASS AND MOMENTUM:
         MOMENTUM INTERFACE MODEL:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = None
         AXIS DEFINITION:
         END
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface Ducts RotatingCoolingDX Xdir
     Boundary List1 = Interface Ducts RotatingCoolingDX Xdir Side 1
     Boundary List2 = Interface Ducts RotatingCoolingDX Xdir Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface Ducts RotatingCoolingDX Zdir
     Boundary List1 = Interface Ducts RotatingCoolingDX Zdir Side 1
     Boundary List2 = Interface Ducts RotatingCoolingDX Zdir Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface Eulerian Intake
     Boundary List1 = Interface Eulerian Intake Side 1
     Boundary List2 = Interface Eulerian Intake Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = None
         AXIS DEFINITION:
         END
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface Intake IntakeMaze
     Boundary List1 = Interface Intake IntakeMaze Side 1
     Boundary List2 = Interface Intake IntakeMaze Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = None
         AXIS DEFINITION:
         END
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface IntakeMaze RotatingImpeller
     Boundary List1 = Interface IntakeMaze RotatingImpeller Side 1
     Boundary List2 = Interface IntakeMaze RotatingImpeller Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingBolt RotatingImpeller
     Boundary List1 = Interface RotatingBolt RotatingImpeller Side 1
     Boundary List2 = Interface RotatingBolt RotatingImpeller Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingBolt RotatingShaft
     Boundary List1 = Interface RotatingBolt RotatingShaft Side 1
     Boundary List2 = Interface RotatingBolt RotatingShaft Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingCoolingCENTER RotatingCoolingDX
     Boundary List1 = Interface RotatingCoolingCENTER RotatingCoolingDX Side 1
     Boundary List2 = Interface RotatingCoolingCENTER RotatingCoolingDX Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingCoolingDX RotatingShaft
     Boundary List1 = Interface RotatingCoolingDX RotatingShaft Side 1
     Boundary List2 = Interface RotatingCoolingDX RotatingShaft Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = None
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingCoolingSX RotatingCoolingCENTER
     Boundary List1 = Interface RotatingCoolingSX RotatingCoolingCENTER Side 1
     Boundary List2 = Interface RotatingCoolingSX RotatingCoolingCENTER Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingImpeller RotatingSpillage
     Boundary List1 = Interface RotatingImpeller RotatingSpillage Side 1
     Boundary List2 = Interface RotatingImpeller RotatingSpillage Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingImpeller Volute
     Boundary List1 = Interface RotatingImpeller Volute Side 1
     Boundary List2 = Interface RotatingImpeller Volute Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingSpillage RotatingCoolingSX
     Boundary List1 = Interface RotatingSpillage RotatingCoolingSX Side 1
     Boundary List2 = Interface RotatingSpillage RotatingCoolingSX Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface RotatingSpillage SpillageSX
     Boundary List1 = Interface RotatingSpillage SpillageSX Side 1
     Boundary List2 = Interface RotatingSpillage SpillageSX Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface SpillageCENTER RotatingSpillage
     Boundary List1 = Interface SpillageCENTER RotatingSpillage Side 1
     Boundary List2 = Interface SpillageCENTER RotatingSpillage Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface SpillageCENTER SpillageDX
     Boundary List1 = Interface SpillageCENTER SpillageDX Side 1
     Boundary List2 = Interface SpillageCENTER SpillageDX Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = None
         AXIS DEFINITION:
         END
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface SpillageCENTER SpillageSX
     Boundary List1 = Interface SpillageCENTER SpillageSX Side 1
     Boundary List2 = Interface SpillageCENTER SpillageSX Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = None
         AXIS DEFINITION:
         END
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface SpillageDX RotatingCoolingSX
     Boundary List1 = Interface SpillageDX RotatingCoolingSX Side 1
     Boundary List2 = Interface SpillageDX RotatingCoolingSX Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = Automatic
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface SpillageVolute SpillageCENTER
     Boundary List1 = Interface SpillageVolute SpillageCENTER Side 1
     Boundary List2 = Interface SpillageVolute SpillageCENTER Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = None
         AXIS DEFINITION:
         END
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   DOMAIN INTERFACE: Interface Volute SpillageVolute
     Boundary List1 = Interface Volute SpillageVolute Side 1
     Boundary List2 = Interface Volute SpillageVolute Side 2
     INTERFACE MODELS:
       FRAME CHANGE:
       END
       MASS AND MOMENTUM:
           Option = None
         END
       END
       PITCH CHANGE:
         Option = None
         AXIS DEFINITION:
         END
       END
     END
     MESH CONNECTION:
       Option = GGI
     END
   END
   OUTPUT CONTROL:
     RESULTS:
       File Compression Level = Default
       Option = Standard
     END
   END
   SOLVER CONTROL:
     Turbulence Numerics = First Order
     ADVECTION SCHEME:
       Option = High Resolution
     END
     CONVERGENCE CONTROL:
       Length Scale Option = Conservative
       Maximum Number of Iterations = 500
       Minimum Number of Iterations = 1
       Timescale Control = Auto Timescale
       Timescale Factor = 10
     END
     CONVERGENCE CRITERIA:
       Residual Target = 1e-3
       Residual Type = RMS
     END
     DYNAMIC MODEL CONTROL:
       Global Dynamic Model Control = Yes
     END
     INTERRUPT CONTROL:
       Option = Any Interrupt
       CONVERGENCE CONDITIONS:
         Option = Default Conditions
       END
     END
   END
 END
 COMMAND FILE:
   Version = 21.1
   Results Version = 21.1
 END
 SIMULATION CONTROL:
   EXECUTION CONTROL:
     EXECUTABLE SELECTION:
       Double Precision = Yes
       Large Problem = No
     END
     INTERPOLATOR STEP CONTROL:
       Runtime Priority = Standard
       MEMORY CONTROL:
         Memory Allocation Factor = 1.0
       END
     END
     PARALLEL HOST LIBRARY:
       HOST DEFINITION: -------
         Host Architecture String = winnt-amd64
         Installation Root = C:\Program Files\ANSYS Inc\v%v\CFX
       END
     END
     PARTITIONER STEP CONTROL:
       Multidomain Option = Automatic
       MEMORY CONTROL:
       END
       PARTITION SMOOTHING:
         Maximum Partition Smoothing Sweeps = 100
         Option = Smooth
       END
       PARTITIONING TYPE:
         MeTiS Type = k-way
         Option = MeTiS
         Partition Size Rule = Automatic
         Partition Weight Factors = 0.25000, 0.25000, 0.25000, 0.25000
       END
     END
     RUN DEFINITION:
       Run Mode = Full
       Solver Input File = CFX.def
       Solver Results File = \
         C:/Users/-------/dp0_CFX_35\
         _Solution_35/CFX_003.res
     END
     SOLVER STEP CONTROL:
       MEMORY CONTROL:
       END
       PARALLEL ENVIRONMENT:
         Number of Processes = 4
         Start Method = Intel MPI Local Parallel
         Parallel Host List = ------*4
       END
     END
   END
 END
 |                            Partitioning                            |
 |                     ANSYS(R) CFX(R) Partitioner                    |
 | 2021 R1                                                            |
 | Build 21.1 2020-11-09T17:12:37.550718                              |
 | Mon Nov  9 19:04:23 GMTST 2020                                     |
 |                        Executable Attributes                       |
 |           double-64bit-int32-archfort-optimised-std-lcomp          |
 | (C) 1996-2021 ANSYS, Inc.                                          |
 | All rights reserved. Unauthorized use, distribution or duplication |
 | is prohibited. This product is subject to U.S. laws governing      |
 | export and re-export. For full Legal Notice, see documentation.    |
 |                  Job Information at Start of Run                   |
 Run mode:       partitioning run
 Host computer:  ---- (PID:------)
 Job started:    Tue Feb  8 10:08:49 2022
 |                        License Information                         |
