Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Optimetrics post analysis display › Reply To: Optimetrics post analysis display
May 23, 2023 at 6:27 am
As you stated that this issue happens sometimes, it is required to check your simulation model from our side to check the actual cause. But, this is not possible through the learning forum because of its open nature. If you have service access, then submit a case on the same.
Best regards,
Praneeth.
