Ansys Learning Forum Forums Discuss Simulation General Mechanical Mesh Error: Cannot Mesh as One Body but Can Mesh Individually Reply To: Mesh Error: Cannot Mesh as One Body but Can Mesh Individually
Rahul Kumbhar
There is no limit. As indicated by the error, the faces may be intersecting in the thin region causing meshing error. If you are able to mesh by splitting then additionally use share topology or bonded contact. The result should be same as single body.
