Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Solid desiccant dehumidifier › Reply To: Solid desiccant dehumidifier
April 4, 2023 at 1:18 pm
I can explainÂ
I have only two dataÂ
- Inlet temperature 301.05 k
- Relative humidityÂ
Here have a hexagonal shape pipe 125mm lengthÂ
silica gel absorb the water vapour in air.
here I am usedÂ
steadyÂ
model was k epsilon- RNG - standard wall treatmentÂ
in material
Spicies transport on make mixture of water vapour + air
in spicies transport- volumetric on and inlet diffusion on
i don't know that right or wrong
please correct meÂ
I objective was outlet temperature will be higher than inlet temperature and outlet RH will be decrease compared to inlet RH
REGENERATION TEMPERATURE- 328.15
pipe made of silica gel
