Ansys Learning Forum Forums Discuss Simulation General Mechanical Pipe pressure load error with shared topology Reply To: Pipe pressure load error with shared topology
Naresh Patre
Under Connections branch of Mechanical if you add a new Connection group and set Face/Edge and Edge/Edge option as "Yes" and generate contacts, this should automatically generate contacts between the edge and the face. Can you try out this option and see if it helps?
