Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Command(APDL) Scripting in Workbench for solution and postprocessing › Reply To: Command(APDL) Scripting in Workbench for solution and postprocessing
erik.kostson
Hi
Perhaps this helps
To have a temp. dependent heat generation use this:
/forum/forums/topic/internal-heat-generation-depending-on-temperature/
