Ansys Learning Forum › Forums › Kampus Merdeka Belajar › Convergency in mass flow rate › Reply To: Convergency in mass flow rate
Muhammad Rizky Pratama Hakim
Dear Leo,
The CFD solution should satisfy the continuity equation. If the density of the fluid is not constant, it may happen the difference between the inlet and outlet mass flow rates, because the density is changing over time. If the problem is not transient, you should check again your simulation setting to make sure it is already right.
