Ansys Learning Forum Forums Discuss Simulation General Mechanical Deformation of a simple bolt connection with bolt pretension Reply To: Deformation of a simple bolt connection with bolt pretension
tim.dietl
Hello Peter, thanks for your answer.
When the red face ends, thats the point wher the threads on the shank touch the threads in the hole.
First step: bolt pretension
second: working load ( 5,5MPa Pressure)
Here it says adjustment reaction: 0,1736mm.
And deformation = FL/AE = 48458N*42mm/(2*10^5MPa*PI/4*12^2) = 0,089977mm
I am confused?
