Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Problem with beams in SC › Reply To: Problem with beams in SC
peteroznewman
Create a radial plane through one of the beams and the axis of the cylinder. Select the Beam, click the Move tool, drag the origin of the Move Triad and drop it on the Plane. Click the arrow that is in the direction you want to move. Type U to use the Up To option, then select the cylinder.
Delete the 7 other beams. Select the Beam, and click on the Move tool. Drag the origin of the Move Triad to the axis of the cylinder. Hold down the Ctrl key while draging on the curved direction of the triad, and type in 45. Repeat 6 times.
On the Workbench Tab, click the Share button.
