Ansys Learning Forum Forums Discuss Simulation General Mechanical Convergence issues with material model changes Reply To: Convergence issues with material model changes
Miguel Sanchez
I would say the problem must be the your second guess since the beams orientation appear correct also in Mechanical:
... but the original geometry rendering shows some defects too: the leg beams do not appear in their corresponding correct blue color...
So, what do I do with/after that? How the hell do you spot and correct a bug in the code?!
