Govindan Nagappan
It might help to see an image of the model.
If the default mesh method fails, use a different method. Default method for shell model is quad dominant. Istead isert a method control and use Multizone quad/tri
Try changing mesh settings, reduce size, turn off defeature size and see if it helps
Try splitting the surfaces, and see if it helps
