Ansys Learning Forum Forums Discuss Simulation General Mechanical Convergence issues with material model changes Reply To: Convergence issues with material model changes
peteroznewman
I believe the beam rendering will be greatly improved by using much longer beam elements. Instead of 2 mm element size on the beams, try 50 mm. Does that improve the beam rendering?
