Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Stuck at load step 1 › Reply To: Stuck at load step 1
March 22, 2023 at 3:32 pm
May be unconnected to your question but why are you getting load step 1 again and again with increasing time. Are you getting out of /SOLUTION module after the SOLVE command and then getting back in? If you are, you are not continuing the analysis from time 10 to time 20 to time 30. Instead you are solving new at time=10, time=20 etc.
