Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Geometry Scope for Arbitrary crack method › Reply To: Geometry Scope for Arbitrary crack method
Vinayak Vipradas
Hi Divya,
You can scope a geometry selection of an Arbitrary Crack to one solid body only. Moreover, you can only use one surface body while scoping a crack surface, and the surface body cannot be enclosed inside the solid body.
Thanks & Regards,
Vinayak Vipradas
