Ansys Learning Forum › Forums › Discuss Simulation › Fluids › the method to define cell temperature in named expression › Reply To: the method to define cell temperature in named expression
DrAmine
As you are not liniarzing you can directly provide the source term via Fluent Expressions. Please check your region you are trying to emit the source if it is correct.
