Ansys Learning Forum Forums Discuss Simulation Fluids why don’t need to set any property ignite point in non-premixed combustion Reply To: why don’t need to set any property ignite point in non-premixed combustion
CHIEH TING WANG
ok ! thanks with your reply
so I do this case without setting any ignition but still can cause the chemistry happened the reason is the pdf and the pdf can make it happened was followed by  Arrhenius type chemistry?
