Ansys Learning Forum › Forums › Discuss Simulation › Fluids › why don’t need to set any property ignite point in non-premixed combustion › Reply To: why don’t need to set any property ignite point in non-premixed combustion
March 1, 2023 at 8:05 am
So i try to simulate micro gas turbine wit burn and the species model i chose 【non-premixed combustion chemical equalibrium 】;mass flow inlet has 0.473 kg/s of oxidizer and the temperature was 300k ,the fuel inlet was 0.0096 kg/s mixture fraction with CH4 mass fraction set at 1 ,also temperature was set in 300k。
after the calculated the temperature result could appeared over 2000k? is there any property burnt point can be control?
