Ansys Learning Forum Forums Discuss Simulation Photonics P-B phase metalens phase library creation Reply To: P-B phase metalens phase library creation
Guilin Sun
It seems the interpolation might have errors, as the phase cannot be that large.
Please first test the example, make sure everything is duplicated. then change the unit cell to your own, plot the rotaion vs phase again.
Since the source and the monitors are in the same analysis group, make sure their locations are proper.You can also check if the transmission is correct.
