Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Thermal radiation probe results is different from theory › Reply To: Thermal radiation probe results is different from theory
February 28, 2023 at 3:33 pm
I agree, a small 315K surface would not emit thousands of Watts! The incicdent radition seems very high also. Could there be a units issue? Could you describe the model? Are you using the "Perfect" setting in Mechanical? Â
