Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Couldn’t solve the solution. Static structural problem › Reply To: Couldn’t solve the solution. Static structural problem
Rahul Kumbhar
In Mechanical, at the top toolbar, there is Selection tab. use Mesh by ID option under selection tab and enter the element number in the error message. This will highlihgt the element. You can just remesh that body with better mesh.
