Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Measuring mass flow rate through a surface › Reply To: Measuring mass flow rate through a surface
You may need to run a few more iterations. Most real models don't converge in 180 iterations. How do the residuals look?
Please replot the contour with node values off, that's a good way to check the mesh resolution.
