Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Heat Transfer Rate › Reply To: Heat Transfer Rate
That's a non-conformal interface, not a wall. That's most likely why it's not a valid surface for expressions as the walls generated are purely to block flow, not to be displayed etc.
So, why did you not create a conformal mesh?
