Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › solution to procedure entry point error pow2o3 › Reply To: solution to procedure entry point error pow2o3
February 28, 2023 at 5:26 am
I had a similar error The procedure entry point __svml_pow2o32 could not be located in the dynamic link library C:\PROGRA~1\ANSYSI~1\v231\fluent\fluent23.1.0\win64\3d_host\fl2310.exe it was none of the compiler libraries listed above it was the fortran compilers on our workstation.. All I had to do is rename the offending dll svml_dispmd.dll to svml_dispmd.old and it started working.. Im going to find a later version of the fortran compiler to see if that works ok side by side.. Picked this up using procmon.. Hope this helps you..
