Ansys Learning Forum › Forums › Discuss Simulation › 3D Design › Soil container modeling – Mohr Coulomb (Material) › Reply To: Soil container modeling – Mohr Coulomb (Material)
February 27, 2023 at 10:07 pm
Greetings Peter
I answer your questions below
- What version of ANSYS are you working with? 2022 R1 - Free Student license
- Are the interleaved rubbers the same size as the aluminum tubes? The rubbers and the aluminum profiles have the same base (where the union of both is), but different height (not very noticeable).
- Are the aluminum tube geometry solid bodies with a wall thickness or are they sheet bodies with a thickness property entered in Mechanical? They are solid bodies with a wall thickness.
Thank you very much for your help
Maria Fernanda
