Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Acoustic pressure calculation LES + FH-W › Reply To: Acoustic pressure calculation LES + FH-W
February 27, 2023 at 7:09 pm
Hi Federico,
Thank you for answering my question. I have not consider about 'acoustic courant number'. Honestly I haven't understand how Fleunt calculate the acoustic pressure. Does the acoustic model use the explicit method?Â
This is the additional information and questions of my calculation. I would be happy if you could answer my questions.
- The narrow pipe has 0.01 [in] mesh, it is generated by face mesh. The wider pipe has 0.1 [in] mesh. Since I am thinking the acoustic source is at the narrow pipe.Â
- The time step size is 5e-5 [sec]. And acoustic far field speed is 1115.486 [ft/sec]. I'm not familiar with acoustic courant number, but it is C = Vdt/dx = 1115.486 [ft/sec] x 5e-5 [sec]/0.01 [in] = 80. This means that I should increase the mesh size or decrease the time step size. Is this calculation correct?
- Because I wanna see the frequency lower than 10,000 Hz, 5e-5 [sec] is enough in terms of frequency.Â
- I'm sorry I couldn't get 'A good rule of thumb is to have at least 10 points for a half-period of the pressure signal with highest frequency' means. What is the half-period of the pressure signal?
Please let me know if you need more information.Â
