Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Initialization Error – Droplet Evaporation › Reply To: Initialization Error – Droplet Evaporation
February 27, 2023 at 4:57 pm
Use UDMs to show what the equation is giving, the rate of change may be significantly higher than you were expecting. You may need to fix the mass exchange rate in the panel using Lee model or the like.Â
