Ansys Learning Forum › Forums › Installation and Licensing › Ansys Free Student Software › Unable to locate or start COM engine on “Local Machine” : unable to create engin › Reply To: Unable to locate or start COM engine on “Local Machine” : unable to create engin
ANSYS_MMadore
Are you trying to run the job locally or across multiple machines? Can you try disabling your firewalls to see if that is causing the behavior?
