Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Conjugate heat transfer analysis on ic engine › Reply To: Conjugate heat transfer analysis on ic engine
Rahul
When the coupled analysis is created in System Coupling's GUI or CLI, the coupling workflow requires a System Coupling participant setup file (.scp) written by Fluent. Please refer 44.2. Performing System Coupling in the GUI or CLI (ansys.com) to writre .scp file from fluent.
Hope this helps!
