Ansys Learning Forum Forums Discuss Simulation LS Dyna Base ball deformation study using explicit analysis Reply To: Base ball deformation study using explicit analysis
peteroznewman
Note that when you changed 10 degrees of rotation to 20 degrees, you doubled the velocity of the bat.
Use the Body filter and select the ball then insert a result Deformation > Directional Velocity. Set the direction to the Y axis.
Here is a post about Contact Force vs Time.
