Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Base ball deformation study using explicit analysis › Reply To: Base ball deformation study using explicit analysis
peteroznewman
Even if you move the rotation of the bat to a coordinate that is 2000 mm, a 10 degree angle is insufficient to reach the ball.
Fix those two problems and the bat will hit the ball.
