Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Absurd Streamlines › Reply To: Absurd Streamlines
February 25, 2023 at 8:24 am
I'm not sure if I understand the issue correctly. Is it related to the post-processing of data using streamlines or the accuracy of the calculated drag values?
If you are concerned about the accuracy of drag calculations, it's recommended to verify the results using force reports.
Thanks!
Nikhil
