Ansys Learning Forum Forums Discuss Simulation Fluids temperature limited to 1 in 50 cells Reply To: temperature limited to 1 in 50 cells
Nikhil N
It appears that you are encountering an issue that may occur early on in your solution, but should improve as you continue to iterate. However, if the issue persists, it may indicate that the energy equation is struggling to converge, which can be caused by using a mesh of poor quality. Could you please provide me with the maximum skewness and orthogonality values of your mesh?
Thanks!
Nikhil
