Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › What theory or solution that ansys use for analysis the part damage? › Reply To: What theory or solution that ansys use for analysis the part damage?
Suwitcha Titaram
Thank you for your advised. Ok from that damage generate from default program setting.
Could you please explain to me know ? How i can use data or result from explicit funtion ?
Because now i can't finding theory or solution for support to compare result from this program analysis.
I would like to be ensure data from program as same theory.
I only know the animation report and data report from program but can't find the raw solution that program solve from my parameter.
Then i can't judgement what my parameter impact for the result.
Can you recommend some theory or solution that i can reference ?
