Ansys Learning Forum Forums Discuss Simulation Fluids ICEM edit mesh after geometry changes Reply To: ICEM edit mesh after geometry changes
ll00023
based on what you suggested, I will save the blocking and geometry separately.
after I edit the geometry, then I can import blocking and modify the blocking accordingly.
I will try this method and come back to this post.
Thank you, Keyur.
