Ansys Learning Forum › Forums › Discuss Simulation › Fluids › SIGSEGV Error when using dissipation rate in UDF › Reply To: SIGSEGV Error when using dissipation rate in UDF
February 24, 2023 at 11:34 am
Probably, bear in mind as you change the turbulence option that it may alter where the C_D data is kept. Mixture and Dispersed probably retain the mixture level but per phase may not.Â
