Ansys Learning Forum Forums Discuss Simulation Preprocessing Meshing error for Unbound variable Reply To: Meshing error for Unbound variable
mjmiddle
Hello Mit,
What application are you using? Share topology is not done as part of the mesher. This is done inside SpaceClaim or DesignModeler. SpaceClaim has a built-in mesher which is a more advance multizone, but otherwise the geometry is usually transferred to the Meshing Application or Mechanical inside workbench for meshing (there are a few other choices on where to mesh and transfer from there).
I am not familiar to this error, but the term "platform" refers to the operating system, such as Windows 10, 11, Linux Red Hat Enterprise 7, 8 , etc... The following page shows supported operating systems per application for Ansys 2023 R1 products:
https://www.ansys.com/content/dam/it-solutions/platform-support/ansys-2023-r1-platform-support-by-application.pdf
I see a mention of the unbound variable error in Fluent knowledgebase solution 2041270:
Check to see if you have the below variable defined. If not, please define it.
LANG = en_US
or
LANG = C
This issue has been seen with :
RHEL 6.7 machine
German language
