Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Topology Inverse Design › Reply To: Topology Inverse Design
azbader
Thank you, Guilin for your help!
Following up with the definition of the FOM, you mentioned that the FOM that is plotted is the inserion loss. What about what is defined in the python code as Target_FOM, is that also the insertion loss or is that T_Up?
Thanks a lot!
Azadeh
