Ansys Learning Forum Forums Discuss Simulation Photonics parameters in Fossum in SRH recombination Reply To: parameters in Fossum in SRH recombination
Guilin Sun
I personally think that there is no "right" value for all the cases, since it depends on the material and process techniques . You can choose one that fits your device, and the result is reasonable.
As for the high field mobility, you may choose different mechanism and test if it works for you. You may also modify the vsta values.
