Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Unit of Ffowcs Williams Hawkings model › Reply To: Unit of Ffowcs Williams Hawkings model
YH
Hi Rob,
Thank you so much for the reply. I know the pressure is extreamly high whether it is in Pa or psi. I think this is beacuse of the receiver's position, since I set up the receivers close to the sound source.  In order to consider about this reason, the unit is important for me.
I'm not sure if this acoustic model follows the Ansys Fluent unit system. I searched in the user guide, but it doesn't help me. Would you tell me the way to identify it?
