Ansys Learning Forum Forums Discuss Simulation Fluids PROBLEM IN RESTARTING a Simulation: Overset domain DOESN’T return to initial pos Reply To: PROBLEM IN RESTARTING a Simulation: Overset domain DOESN’T return to initial pos
The position is updated due to the flow field, and the starting position is based on where it was when you read in the mesh, it is not retained in the solver. Whenever doing any moving mesh problems I always save a t=0 case and data for use in restarts.Â
