Ansys Learning Forum Forums Discuss Simulation Electronics Current per conductor in parallel Reply To: Current per conductor in parallel
HDLI
Hello Coleen,
      To simulate different current distribution, it will be a little complicated process. I suggest to use coupling between Q3D and Simplorer to simulate each current of each terminals. You will get different shared current results.
      After that, you could export current results from Simplorer model and import them into Maxwell for field simulation, if you need.
Howard
