Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Profile Interpolation Error › Reply To: Profile Interpolation Error
Facets in Fluent: data is stored in cell centre for the volumes and on the facet for defined surfaces. Depending on how you recorded the data (ie boundary surface) you may also see some influence from the neighbouring cell value. The value USED in Fluent is as defined, the report may see some influence.
